I ran my ccleaner this morning, all was fine. I then went to the 'registry' tab & clicked on 'scan for issues'. The list is quite long. I saved the report to a text file. I honestly have no idea what I should do here. It has a tab that says "fix selected issues". I don't know if I should click the tab and/or what boxes need to be checked or unchecked so I don't break anything.
I would greatly appreciate any help with this. I can even send the file if you're interested.
Thank You & God Bless
