My Video Hard Drive accidentily got deleted. Recuva shows every video except .ts (transport stream).
Thanks in advance for help.
Recuva will show every deleted file it finds in a normal scan, whatever the extension. It will also find ts files in a deep scan.
What exactly is the problem? Are you running a normal scan, are ts files shown in the scan results, or yes to both but you can't recover them?
