NEED HELP PLEASE RE PASSWORD DELETION
I apologize if this is not the proper place to post this, or if it's been brought up, but I use both IE9 and Safari browsers.
When I run CCleaner and then go on Safari to sign into iCloud it doesn't seem to recognize my password, and when I try again, and then again...it makes me reset my password...which is a real pain in the you know what...because then I have to make up a totally new password (one I haven't used for a year) and then I have to reset it on my iPhone, and then I have to reset it in Outlook 2010.
How can I prevent CCleaner from wiping out my passwords so i don't have to continue to reset my passwords....it makes me not want to use CCleaner very often.
Thanks for your help and again I apologize if this is the wrong place to post this, but I'm new, and somewhat computer illiterate.
Hi HesDanTheMan.
You need to prevent CCleaner from deleting the cookies which may contain your log in information. Instructions here ..
http://www.piriform....cookies-to-keep
Some websites use "Flash" cookies to store this information, so if the above doesn't work, then try unchecking "Adobe Flash Player" in "Cleaner\Applications\Multimedia".
Hope that helps.
