Need help interpreting RAM frequency results from Speccy.
I know my stick of RAM has an 800MHz frequency, but Speccy only lists 400 MHz. I take it it's just halving the number. So, if I have DDR3 do I multiply the MHz by 3, and 4 for DDR4? What about RDRAM? (One of my systems has some.) Is RDRAM just the number listed?
You are probably mixing MT and MHz, check this thread: http://forum.piriform.com/index.php?showtopic=38723
Wiki briefly explains.
Yeah, it looks like I am doing that. I wish manufacturers actually listed units on their products. Thanks for the help.
How would I calculate the MT of RDRAM? I don't believe it is dual channel.
http://en.wikipedia.org/wiki/RDRAM
Yeah, I've read that. That source taken with other sources isn't exactly clear on RDRAMs transfer rate. So, again how would I calculate the MT of RDRAM?
Type explain RDRAM into your web search engine and you'll get oodles of sites explaining enough details to make you an expert. :)
They don't say it directly.
You couldn't possibly have perused all those sites.
Sorry, I'm not gonna do your homework for you. Have enough of my own. :P
They're just not written very clearly and some of them have contradictory information, unlike crucial's FAQ on DDR. The best I've found is the reason for why RDRAM is no longer used, mainly a price fixing scheme from the DDR manufacturers in the early 2000's.
At first I started to think the MHz value is just multiplied by 2 to get the data transfer rate of RDRAM, but then in the same article they mention certain RDRAM chips don't follow that rule. Namely on, PC600 RDRAM runs at 266 MHZ, while PC800 RDRAM runs at 400MHZ.
PC800 RDRAM runs at a clock of 400 MHz and it uses a DDR-way of transporting the data. Thus the 16 bit or 2 Byte data are transported at 800 MHz, explaining the '800' in PC800. ....
if you think that PC600 stands for 300 MHz you're dead wrong. PC600 RDRAM runs at 266 MHz
Link to the article
So, what's the correct formula for calculating transfer rate? Multiplying by 2 seems accurate in some cases but not all,
When you know the formula, how will that enhance your computer or quality of life :rolleyes:
You have linked to an article on tomshardware site.
Why not ask for clarification on their forum ?
http://www.tomshardw...m/forum-74.html
I'm reselling RAM and want to make sure I have the right specs listed.
I suggest you specify it in the same way that it was specified by your supplier or the manufacturer.
