Need Help...CCleaner did not remove
I have been getting an error on my computer for several months now. It is: C:\ProGra 1\MyWebs 1\bar\1 bin\M3PLUGIN.DLL Error
I did a search on Google and found information that this CCleaner would remove this particular error. I have downloaded the CCleaner and ran it, however it did not correct the problem. Can anyone help with this? Thank you!
Is your problem similar to here?
http://answers.yahoo.com/question/index?qi...07230622AAlUW0y
Yes, that is the error. I did follow the suggested steps but my computer did not have anything that needed to be removed. They were all like they should be so hopefully someone will know something else to try. Thank you.
You need to head over to the Spyware Hell forum to get this removed
