My computer freezes and not responding when accessing SMART data
1. When Speccy is gathering SMART status of HDD then computer hangs and CPU utilization becomes at 100%, HDD LED is on permanently. Trying to run speccy.exe with /debug command line switch does not provide any logs.
2. Update CPU data, Update Video data, Update SMART data. What are these settings do?
My system is guaranteed to work stable.
Sorry for bad English :(
Software:
Windows XP SP3, nForce3 Driver 5.03
Hardware:
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type AMD Athlon 64, 2200 MHz (11 x 200) 3200+
CPU Alias Newcastle S754
CPU Stepping DH-CG
Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2
Original Clock 2200 MHz
Min / Max CPU Multiplier 4x / 11x
L1 Code Cache 64 KB (Parity)
L1 Data Cache 64 KB (ECC)
L2 Cache 512 KB (On-Die, ECC, Full-Speed)
CPU Physical Info:
Package Type 754 Pin uOPGA
Package Size 4.00 cm x 4.00 cm
Transistors 68.5 million
Process Technology 9Mi, 0.13 um, CMOS, Cu, SOI
Die Size 144 mm2
Core Voltage 1.500 - 1.550 V
I/O Voltage 1.2 V + 2.5 V
Maximum Power 89.0 W
CPU Utilization:
CPU #1 0 %
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID 09/07/2006-nForce-6A61CPAFC-00
Motherboard Name Epox EP-8KDA3I
Front Side Bus Properties:
Bus Type AMD Hammer
Real Clock 200 MHz
Effective Clock 200 MHz
HyperTransport Clock 800 MHz
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio CPU/11
Real Clock 201 MHz (DDR)
Effective Clock 402 MHz
Bandwidth 3215 MB/s
Motherboard Physical Info:
CPU Sockets/Slots 1 Socket 754
Expansion Slots 6 PCI, 1 AGP
RAM Slots 3 DDR DIMM
Integrated Devices Audio, LAN
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset nForce3-250
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Patriot Memory PSD1G400 ]
Memory Module Properties:
Module Name Patriot Memory PSD1G400
Serial Number None
Module Size 1 GB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 200 MHz 3.0-4-4-8 (CL-RCD-RP-RAS) / 12-14-2 (RC-RFC-RRD)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
[ DIMM2: Patriot Memory PSD1G400 ]
Serial Number None
Module Width 64 bit
Memory Timings:
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: AMD Hammer IMC ]
North Bridge Properties:
North Bridge AMD Hammer IMC
Supported Memory Types DDR-200 SDRAM, DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Revision 00
In-Order Queue Depth 8
Memory Timings:
CAS Latency (CL) 3T
RAS To CAS Delay (tRCD) 4T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 8T
Row Cycle Time (tRC) 12T
Row Refresh Cycle Time (tRFC) 14T
Command Rate (CR) 2T
RAS To RAS Delay (tRRD) 2T
Write Recovery Time (tWR) 3T
Read To Write Delay (tRTW) 4T
Write To Read Delay (tWTR) 2T
Write CAS Latency (tWCL) 1T
Refresh Period (tREF) 200 MHz 7.8 us
DQS Skew Control Disabled
DRAM Drive Strength Normal
DRAM Data Drive Strength 4 (No Reduction)
Max Async Latency 7 ns
Read Preamble Time 5.5 ns
Idle Cycle Limit 16
Dynamic Idle Cycle Counter Enabled
Read/Write Queue Bypass 8
Bypass Max 4
32-byte Granularity Enabled
Error Correction:
ECC Supported, Disabled
ChipKill ECC Not Supported
RAID Not Supported
DRAM Scrub Rate Disabled
L1 Data Cache Scrub Rate Disabled
L2 Cache Scrub Rate Disabled
Memory Slots:
DRAM Slot #1 1 GB (PC3200 DDR SDRAM)
DRAM Slot #2 1 GB (PC3200 DDR SDRAM)
[ South Bridge: nVIDIA nForce3 250Gb/Ultra (CK8S) ]
South Bridge Properties:
South Bridge nVIDIA nForce3 250Gb/Ultra (CK8S)
Revision A2
Package Type 752 Pin BGA
Process Technology 0.15 um
AGP Controller:
AGP Version 3.00
AGP Status Enabled
AGP Device ATI Radeon HD 4670 AGP (RV730), ATI RV710/730/740 - High Definition Audio Controller
Supported AGP Speeds 1x, 2x, 4x, 8x
Current AGP Speed 8x
Fast-Write Supported, Enabled
Side Band Addressing Supported, Enabled
Clock Generator:
CPU FSB 200.0 MHz
HyperTransport 800.0 MHz
PCI 33.3 MHz
AGP 66.7 MHz
MII 25.0 MHz
MAC PHY 125.0 MHz
SATA PHY 100.0 MHz
Audio/Modem Codec 24.6 MHz
USB2 Controller 48.0 MHz
PIT / ACPI Timer 14.3 MHz
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Award
BIOS Version 09/07/2006 For nForce3 250 Chipset
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message 09/07/2006 For nForce3 250 Chipset
System BIOS Date 09/07/06
Video BIOS Date 06/03/09
--------[ PCI / AGP Video ]---------------------------------------------------------------------------------------------
ATI Radeon HD 4670 AGP (RV730) Video Adapter
ATI Radeon HD 4670 AGP (RV730) 3D Accelerator
--------[ PCI / PnP Audio ]---------------------------------------------------------------------------------------------
ATI Radeon HDMI @ ATI RV710/730/740 - High Definition Audio Controller PCI
Creative SB X-Fi Fatality XtremeGamer Sound Card PCI
--------[ Physical Drives ]---------------------------------------------------------------------------------------------
[ Drive #1 - WDC WD2500KS-00MJB0 (232 GB) ]
#1 (Active) NTFS C: (SYSTEM) 0 MB 33675 MB
#2 NTFS D: (DATA) 33675 MB 204797 MB
[ Drive #2 - WDC WD800JD-22LSA0 (74 GB) ]
#1 (Active) NTFS T: (TEMP) 0 MB 76316 MB
[ Drive #3 - KingstonDataTraveler 2.0 (1968 MB) ]
#1 (Active) NTFS F: 0 MB 1967 MB
--------[ ATA ]---------------------------------------------------------------------------------------------------------
[ WDC WD2500KS-00MJB0 (WD-WCANKJ194658) ]
ATA Device Properties:
Model ID WDC WD2500KS-00MJB0
Serial Number WD-WCANKJ194658
Revision 02.01C03
Device Type SATA-II
Parameters 484521 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 488397168
Buffer 16 MB
Multiple Sectors 16
ECC Bytes 50
Unformatted Capacity 238475 MB
ATA Standard ATA/ATAPI-7
ATA Device Features:
48-bit LBA Supported
Advanced Power Management Not Supported
Automatic Acoustic Management Supported, Disabled
Device Configuration Overlay Supported
DMA Setup Auto-Activate Not Supported
General Purpose Logging Supported
Host Protected Area Supported, Enabled
In-Order Data Delivery Not Supported
Native Command Queuing Not Supported
Phy Event Counters Supported
Power Management Supported, Enabled
Power-Up In Standby Supported, Disabled
Read Look-Ahead Supported, Enabled
Release Interrupt Not Supported
Security Mode Supported, Disabled
SMART Supported, Enabled
SMART Error Logging Supported
SMART Self-Test Supported
Software Settings Preservation Supported, Enabled
Streaming Not Supported
Tagged Command Queuing Not Supported
Write Cache Supported, Enabled
SSD Features:
Data Set Management Not Supported
Deterministic Read After TRIM Not Supported
TRIM Command Not Supported
[ WDC WD800JD-22LSA0 (WD-WMAM9D811607) ]
Model ID WDC WD800JD-22LSA0
Serial Number WD-WMAM9D811607
Revision 06.01D06
Device Type SATA-II
Parameters 155061 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 156301488
Buffer 8 MB
Multiple Sectors 16
ECC Bytes 65
Unformatted Capacity 76319 MB
Power-Up In Standby Not Supported
Security Mode Not Supported
SSD Features:
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 51 200 200 0 OK: Value is normal
03 Spinup Time 21 253 213 2308 OK: Value is normal
04 Start/Stop Count 0 97 97 3186 OK: Always passes
05 Reallocated Sector Count 140 200 200 0 OK: Value is normal
07 Seek Error Rate 51 200 200 0 OK: Value is normal
09 Power-On Time Count 0 83 83 12743 OK: Always passes
0A Spinup Retry Count 51 100 100 0 OK: Value is normal
0B Calibration Retry Count 51 100 100 0 OK: Value is normal
0C Power Cycle Count 0 97 97 3184 OK: Always passes
BE Airflow Temperature 45 75 53 25 OK: Value is normal
C2 Temperature 0 125 103 25 OK: Always passes
C4 Reallocation Event Count 0 200 200 0 OK: Always passes
C5 Current Pending Sector Count 0 200 200 0 OK: Always passes
C6 Offline Uncorrectable Sector Count 0 200 200 0 OK: Always passes
C7 Ultra ATA CRC Error Rate 0 200 200 3 OK: Always passes
C8 Write Error Rate 51 200 200 0 OK: Value is normal
03 Spinup Time 21 168 165 2591 OK: Value is normal
04 Start/Stop Count 0 96 96 4389 OK: Always passes
09 Power-On Time Count 0 76 76 17919 OK: Always passes
0C Power Cycle Count 0 96 96 4387 OK: Always passes
BE Airflow Temperature 45 78 42 22 OK: Value is normal
C2 Temperature 0 121 85 22 OK: Always passes
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes
