Mui cache and totally system event cleaner
Hi all, my suggestion is to add a MUI cache cleaner for windows 7 x64 ( cc cleaner not clear it ...and i don't kow why .... for now i use MUICacheView v1.01 to read and delete the MUI cache)
and totally system event cleaner is very usefull! now i use a batch file, that i found on my internet search and works very well, here is the code
@echo off
FOR /F "tokens=1,2*" %%V IN ('bcdedit') DO SET adminTest=%%V
IF (%adminTest%)==(Access) goto noAdmin
for /F "tokens=*" %%G in ('wevtutil.exe el') DO (call :do_clear "%%G")
echo.
echo Event Logs have been cleared! ^<press any key^>
goto theEnd
:do_clear
echo clearing %1
wevtutil.exe cl %1
goto :eof
:noAdmin
echo You must run this script as an Administrator!
echo ^<press any key^>
:theEnd
pause>NUL
I hope that it will be added in the future, bye.
Others will have a different point of view to me, but I don't like the idea of cleaning event logs as they are far too helpful for troubleshooting.
They self-clean when they get to a certain size anyway.
Welcome to the forum snapx.
