I think it was just a matter of time before I messed up.
From time to time I used to have this "page cannot be found" error or whatever that is. Yesterday I was checking some forums & I came across a thread describing exactly the same thing I have w/ my comp.
There were two suggestions to solve the problem. They both suggested to go to Start- run & then type ( in my case "ispflush" I am not too sure as I am at work now, perhaps I'll check it & post it once I get home).
Anyways, I did that, pressed ok after lots of thinking. The result: I can't open pages/close them or click the back button. Can't even go to Start- Turn off.
Iam stumped. I know I did sth stupid.
So any help resolving this problem would be greatly appreciated.
The problem was more than likely with your PS/2 port/connection. Try cleaning it of dust and such and it might start responding again. Often just a reboot helps, so use that Windows key to navigate to Start and Restart.
I had something similar happen on an old computer. I called tech support when I got fed up, and they said. "You need to buy a new mouse." Ironically I already had a new one ordered.
Actually there is a difference in report rate, especially in 9x-kernel environments. With Windows 98 and a PS/2 mouse, the report rate is defaulted to 60 samples per second, whereas a USB mouse defaults to a much higher report rate, making the mouse cursor appear more smooth. Windows NT and higher set both the PS/2 and USB default rate higher than 60... but the difference doesn't stop there...
Um, if you're referring to DOS, USB works fine in it. I access thumb drives and external CD-ROM drives all the time with DOS USB drivers, and USB mice will work in DOS if USB legacy support is enabled and supported by the BIOS... furthermore, Linux and BSD support USB, which are not Windows environments :PPPP
With USB, not only can the sample rate be higher, but the size of the samples can be higher, too, resulting in the confusing "DPI" that nobody seems to understand (even technicians). USB 1.0 is about ~48 MHz.
One more thing... PS/2 is a legacy device because it rides the 8.3 MHz ISA bus (well, nowadays it runs at a whopping 11MHz), which is a piece of crap that we need to ditch but for some reason still exists even in AMD 64 architectures... argh. die ISA, die... Once ISA and everything relying on it is gone, computing will get a bit better..
For the past few weeks my USB mouse started acting up. First I thought it was the table I have my system on, but after polishing it the thing was still jerky. The strange thing is after running NTRegOpt the problem was solved.
