Hello,
I installed Ccleaner pro plus yesterday and today I realize that it has deactivated my wifi card because I can’t connect to the wifi like before installation.
How can I fix this problem?
Looking forward to hearing from you,
Yours sincerely
Hello,
Yours sincerely
Have you updated drivers? In particular the wifi driver.
If so then open the Driver Updater and use the “+ Fix a Problem” button to see if you can roll the driver back again:
Note that the updater will offer you drivers simply because they are ‘newer’ than the one that you have.
But just because a driver is ‘newer’ does not mean that it is meant for your machine.
eg. It could be meant for a different type of wifi card from the same manufacturer as yours, but not the type that your machine has in it.
Personally I don’t use any Driver Updater.
I see how often they offer an incompatible driver just because it is ‘newer’, a driver which if you update to it can stop things working properly on your machine.
If your current drivers are working OK then there is no need to change or update them.
There’s an old saying - If it ain’t broke then don’t try to fix it.
