Monitor Resolution
In Windows 10, with these settings:
Case I
A. Windows Control Panel>Display>Screen Resolution set at 2560x1600 (native resolution of my monitor)
B. NVidia Control Panel>Display>Change Resolution set at 2560x1600 (native resolution of my monitor)
C. Windows Settings>System>Display>Change the size of text, apps and other items set at 100%
Speccy shows the monitor resolution at 2560x1600.
CaseII
When I change
C. Windows Settings>System>Display>Change the size of text, apps and other items set at 150%
Speccy shows the monitor resolution at 1707x1067.
In Windows 7, changing size of text etc. did not change the reported resolution.
My questions: Is Speccy showing the correct resolution in Case II? Is this a problem with Windows 10.
