Rats !!! It`s happening again ! even when i have my monitor switched on before i switch the computer on,the monitor is not powering up and i`ve noticed the keyboard light doesn`t either......I have to press the reset button..
I`m asking for any more ideas ! My graphic card drivers are up to date i believe
Fluffy
As Redhawk asks, does your PC make a "beeping" sound when you first switch on the power?
If so you need to count (very carefully) the exact number of "beeps". So how many "beeps"?
Error reporting
BIOS POST card for ISA bus
BIOS POST card for PCI bus.
Professional BIOS POST card for PCI bus.
A word of caution - POST beep codes
Manufacturers do not all use the same beeps codes and do not seem to observe any standard. It is important before attempting to fix a problem to search for specific information relating to your motherboard and BIOS version. Failure to do this can result in serious damage to a system, as well as wasting time and money.
Original IBM POST beep codes
* 1 short beep - Normal POST - system is OK
* 2 short beeps - POST error - error code shown on screen
* No beep - Power supply, system board problem, disconnected cpu, or disconnected speaker,
* Continuous beep - Power supply, system board, or keyboard problem
* Repeating short beeps - Power supply or system board problem or keyboard
* 1 long, 1 short beep - System board problem
* 1 long, 2 short beeps - Display adapter problem (MDA, CGA)
* 1 long, 3 short beeps - Enhanced Graphics Adapter (EGA)
* 3 long beeps - 3270 keyboard card
POST AMI BIOS beep codes
* 1 - Memory refresh timer error
* 2 - Parity error in base memory (first 64 KiB block)
* 3 - Base memory read/write test error
* 4 - Mother board timer not operational
* 5 - Processor failure
* 6 - 8042 Gate A20 test error (cannot switch to protected mode)
* 7 - General exception error (processor exception interrupt error)
* 8 - Display memory error (system video adapter)
* 9 - AMI BIOS ROM checksum error
* 10 - CMOS shutdown register read/write error
* 11 - Cache memory test failed
* 12 - continue beep sound --- it indicate that the board is not getting ram chip
Reference: AMIBIOS8 Check Point and Beep Code List, version 2.0, last updated 10 June 2008
POST beep codes on CompTIA A+ Hardware Core exam
These POST beep codes are covered specifically on the CompTIA A+ Core Hardware Exam:
Beeps Meaning
Steady, short beeps Power supply may be bad
Long continuous beep tone Memory failure
Steady, long beeps Power supply bad
No beep Power supply bad, system not plugged in, or power not turned on
No beep If everything seems to be functioning correctly there may be a problem with the 'beeper' itself. The system will normally beep one short beep.
One long, two short beeps Video card failure
So Fluffy we need to start with the number of "beeps", and the pattern.
