Use Windows explorer and look for your missing
c:\programmefiles\comodo\comodoantiviru\Emgupd\engAutoupd.exe.
actually, start looking for c:\p*
I think you will find the correct spelling is C:\Program Files.
Similarly proceed through the rest of the path perhaps Comodoantiviru should have a space.
You MAY eventually discover that ...\Emgupd\ does exist, but that it is inaccessible.
Inaccessible folders are one of the "benefits" you get for free with NTFS.
engAutoupd.exe could exist within a folder, and Comodo could know it is there and use it even if its folder is inaccessible.
The folder could be inaccessible due to :-
registry corruption (inevitable "benefit" free with Windows, how I miss *.ini files); or
a side-effect of a battle between Comodo and Malware; or
part of Comodo's self protection.
If you wanted you could probably disable Comodo's protection;
BUT FIRST check on the Comodo forum - I think you could expose yourself to danger and you really need advice before tampering with malware protection.
If it is inaccessible for any reason, then CCleaner will always be told by Windows that engAutoupd.exe does not exist,
and when you clean the MUIcache it will be purged from the registry,
and immediately Comodo next uses engAutoupd.exe then Windows will say "I see you" and dump the reference back in the registry
(why it should do that is any-ones guess - mysteries also come free with Windows !!!).
Regards
Alan.
