Minor problem.....
Hi, Folks!
This is more aggravating than anything else, but it has lasted a while and I figure I'd better ask.
On the last few downloads of CCleaner (at least the last 3 versions) it would download just fine. However, when it attempted to install it, it would go nearly all the way through the process and then hang, leaving the last quarter inch of the bar uncompleted. Sometimes I'd wait as long as an hour or more to allow it to complete the installation, but it never would.
Finally I'd attempt to get out of it only to find the only way to do it is to use Control/Alt/Delete. I would then check for updates and it would say that I had the very latest version, so apparently it installed correctly anyway. It would work just fine until the next version came out and the same thing would happen.
The world's not coming to an end if this isn't solved, but I'm wondering if anyone has an idea about what's happening.
My best to you!
Tom (LoneWolf)
Do you install over the top of the last one?
Have you tried not having check for updates ticked?
Vista or xp?
