Minimize to Tray setting using Windows key method
Computer I use has Windows 7 SP1. With the Minimize to Tray enabled, when I use the WIN+down arrow, or the WIN+M keys to minimize the window or all windows, the CCleaner icon remains on the task bar. However, if I click on the Minimize button or the Alt+spacebar+N method, the program will minize to the tray. Obviously, there's a difference in the miminize method using the Windows key. Is this a bug or can it be an option to go to the tray using the WIN key shortcuts.
