Hello everyone, since I became ccleaner prof. My Office365 is no longer running. After reinstalling it works until I use ccleaner - is the bug known, what can I do?
I’m not sure if it’s a new bug or not. (but it might be).
Is this Windows 10 or 11?
Are you using the Performance Optimizer in CCleaner?
If so then are you letting it put Office to sleep?
If that is the case then please ‘Wake Up’ Office from the Sleeping Programs and let us know if that cures the problem.
Thanks. That helped, in fact I had put Office365 into sleep mode in the free version some time ago - but that only had an effect with the Pro version.
Thanks for letting us know how you got on and solved it.
Others have also reported having issues with Office if they let Performance Optimizer put it to sleep.
I guess the cure for that is simple; don’t add Office to the apps to be put to sleep.
I have the same problem - when I run Cleaner it corrupts my Office 365 and I have to re-install the microsoft programme. I am running windows 11 and the problem just started this week. Office is not in ‘sleep’ mode on Ccleaner programme Optimiser. I have tried sever repair options and done number of uninstall/re-install but the problem persists.
