Microsoft Edge
Why does the cleaner skip Microsoft edge session, Set aside tabs, saved form information, saved cards?
Microsoft Edge is always open by default, so CCleaner can't clean it.
See here:
Try going on your PC to Settings..Privacy.. Background Apps... and turn Microsoft Edge to off which can stop it running in the background.
Thank you all for your advice. I was able to fix the problem. I had no idea so many app could run in the background.
3 hours ago, aj1199 said:
<div class="ipsQuote_contents ipsClearfix">
Good to here it is fixed for you.
I always leave Windows Security running in the background and turn all the others off.
