Messed Up Fonts
I have a little problem with the Windows XP fonts after running CCleaner , i don't think you notice the diference ?
Before running CCleaner
After running CCleaner
After running CCleaner all the fonts appear to be more crisp and irregular. Any solution ? I have CCleaner last version , Win XP Home.
But that's two different browsers... one is using antialiasing ("AM Browser") and the other is not (Firefox).
Nope is not.
Here's another example, is your ''start'' font looking like this (of course if you have XP) ?:
Seems is shaking to me.
I was just going by the fact that you were using screenshots from two different browsers, confusing the issue.
So go turn antialiasing back on: Start > Run > control desk.cpl,,2
Effects > Use the following method to smooth edges of screen fonts: Standard, or Cleartype. Pick whichever looks best to you. I doubt CCleaner changed this.
Worked, thanks! :D
