I noted when you install a new version of Defraggler, it is no problem. The installer can select.
____________________________________________________________________________________________________
But it is confusing having 32 bit Defraggler + 64 bit Defraggler.
Users have to select one customized version for 32 bit, then totally change for a customized 64 bit version for 64 bit Windows!
+ If you run 32 bit defraggler from a flash drive on a 64 bit computer, you may run into problems. You definitely can't run 64 bit software on 32 bit machines!
If the executable could be combined so a user doesn't have to try to have multiple versions of Defraggler just to run on different 32 bit/64 bit machines, it would be much easier!
* Isn't there a way to combine the 32 & 64 bit versions, but just include a script to auto-select for 32 bit EXE on 32 bit platforms, & 64 bit for 64 bit platforms?
In addition to that, since there are no visual cues (such as a system tray icon) to indicate that Defraggler is running in the tray, why not just discard the commandline defraggler & include a script to run the GUI version of Defraggler minimized to the tray or something?
Thanks guys!
