MD5, SHA1 hashes for CCleaner
Hi there,
Since your product is hosted on other sites, would be very helpful to provide MD5, SHA1 hashes on your website.
The good place would be your page where download links are.
The easiest way to generate and check hashes is to use free 'Microsoft File Checksum Integrity Verifier utility'
http://support.microsoft.com/kb/841290
command line usage: fciv.exe filename.exe
Thanks.
It's already been suggested before. :rolleyes:
The setup files are signed with VeriSign for anti-tampering which isn't an issue at all if you only download Piriform software from their main websites, or from FileHippo.com. Note that FileHippo.com lists the MD5.
