hi, 1st post here hope its in the right section
anyway i installed ccleaner on my pc running xp pro and i ran one cleaner scan and deleted all files it found, i did not run the reg scan and mcaffee is missing crucial parts of the program. when i uninstall and reinstall mcaffe security center (free from msn premium) the mcafee install program locks up every time. this same scenerio happened on another xp machine i have. on that one, i thought it was the ccleaner reg cleaner that caused the problem so i installed both programs on the new system and it the same conflict happened after one file cleaning scan and delete. i have not been able to use mcaffee since installing so i did a system restore and am a bit leary of running ccleaner again. i really do like the program though.
Any suggestions, anyone else have this same trouble?
thanks Damian
Are you installing mcaffee in temp folders or something? I don't see how this could be happening.
Make sure your installing Mcaffee in the default location.
well, i do use seperate partitions c is my windows partition d is program files etc. and e is strictly my swap file partition could this possibly be the problem? everything installs to the d partition including ccleaner and mcafee both my affected computers have this partition scheme.
McAfee v5 and v6 utilized the temp folder for storing in-use files like WebScan, etc., and I was always able to kill off components of it merely be cleaning out the temp folder with a batch file - yes it was that easy to completely disable some of it's components. I'm not sure about any versions higher than 6, however if they still place deletable in-use files in the temp folder that could be the cause.
Also if it isn't working after uninstall and then reinstall it could be because of a left over McAfee program folder, McAfee registry entries (it sure as hell won't remove all those), or you need to install under an Admin account, or your registry permissions need to be fixed.
Now that you've stated that try to install McAfee on the C:\ drive and see if it works. I previously had some of my audio programs refuse to work when trying to run them on my D:\ drive - they flat out wouldn't do jack s**t on drive D:\.
thanks folks
ill keep trying and ill try the suggestions
ill report later and thanks for being so prompt!!
ccleaner IS a great program
and so are the people of its forums
Damian
ok its all fixed now!
well ccleaner took outsomething from mcafee. it was probably no big deal mcafee would have kept running fine. but, me being the way i am, i tryed to reinstall mcafee and thats where my problems started. i had installed ie7 beta weeks earlier. thats where my problem really was. the beta of ie7 would not allow me to reinstall mcafee. the version of mcafee which i used uses msn browser to install (and its based on the latest ie you have installed) so i tryed to install mcafee w/ ie7 beta and that is not compatible w mcafee. only if mcafee is already installed. so....ccleaner was just doing what it does well and not to blame for my trouble. just a microsoft beta product which i shldnt have been using anyway .
thanks all
my mistake
ccleaner is a good product
please feel free to remove my post as it really probably wont help many people out there and is sort of off topic.
Damian
Good to hear you figured it out!
Nah, your thread should stay until the next round of maintenance because someone else on the web may actually find the info useful if they face a similiar situation.
