Never had any problem, till I updated ccleaner and run it and additional did item tips
After that gmail, browser, several other app crash. Even Playstore
For Gmail I removed updates but it works for short time and crashes again.
Als "feedback ... market (?) Crasht (dont know what it is)
And briefing crasht (that one I turned off)
I removed ccleaner
How to fix my cellphone (Samsung Galaxy a5 2017)
See examples attached
![Screenshot_20210323-061330_Brave.jpg]()
![Screenshot_20210323-061310_Brave.jpg]()
Also Samsung notes keeps crashing, nothing to do with internet
There was a bugged update to Android on Monday that is/was crashing multiple apps and is most likley the cause of your problems.
A fix has now been released and you need to update both Google Chrome and Android System WebView.
See this for more details::
https://www.theverge.com/2021/3/22/22345696/google-android-apps-crashing-fix-system-webview
Thnx for reply
I followed mentioned steps but it turned out that Android System Webview was already turned OFF! And I cant turn it on...
And I can not turn it on, hence iai can not remove update.
But i doubt this is cause. I used "TIPS" from cccleaner (never did before) and then apps started to crash. And I did not updates Chrome as I dont use that browser on my gsm
I removed updates gmail and now finally gmail is working (i had to do that several times)
When is ccleaner going to fix the bug in "Tips"?!
![Screenshot_20210324-040527_Settings.jpg]()
![20210324_041449.jpg]()
Quote
Whether you use it as a browser or not update Chrome as advised by that article, it's not just the browser that Chrome affects it's threaded throught Android.
If you use gmail you are using parts of Chrome.
And then turn off/restart your phone to refresh the settings.
