manual update not work
I write same before but seems things got just worse. Although i got promised they fix soon and know.
Maybe they know but then .. i dont know.
Before i complain, there come notification of available update, although all settings put to manual, so
i, paid user with pro-version should be one who have right to check if updates available?
Now there was updated program just more and it offers new easy clean type procedure with new graphics etc.
It seems this cc-cleaner is working all time background in internet although i have manual update
settings. Only solution then would be to use firewall settings to stop this?
Do you program developers want that? I recommend put it to cc-cleaner new update, all internet
connections are manual to updating program. Although otherwise settings would be like program
works in background, like when i close browser, some auto-cleaning then done.
