I have been experiencing a major sound problem since a few months.
After a few minutes of gameplay in any computer game, I start getting scratchy and distorted noise. I don't get this problem when I listen to music or watch a video. It does not stop unless I reboot the computer.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: All tests were successful.
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found. DirectPlay test results: All tests were successful.
I'm guessing you're using onboard audio since it doesn't appear like you use a sound card. Whats the make and model of your mobo? Are you using speakers or headphones? Have you tried switching around your speakers, etc. to make sure that's not the source of your problem? Also try unplugging and replugging the wires, jiggling them around a little bit whenever the problem pops up.
That's a nice mobo so I don't think that there's a problem with onboard sound. I did some research and it looks like the speakers become kind of scratchy above 75% volume. Try setting the speaker volume lower, while raising Windows volume and the application's volume.
I'll keep looking, I haven't yet found something that relates exactly to your problem yet.
I had the cracking sound crap on my previous system. Sometimes unplugging the speakers from the powerstrip would do the trick however it turned out to be the powerstrip itself that I was using, and buying a new Belkin powerstrip specifically rated for computers did the trick for me. If you get a new powerstrip make sure you get one that's rated for your CPU, e.g.; 2.6 Ghz, 3.2 Ghz, etc., the supported CPU range is printed on the box if you get a Belkin.
I just listened during 2 hours to Judas Priest and all went smooth. :/
Sounds good, I think I'll put on some JP right now!
