Just wondering... I use Macrium Reflect Pro and create fairly regular images. So, is a app like Keriver 1-Click Restore also needed, or is this just duplicity?
Give it a try Tom, and let us know how you get on.
Never heard of it before to be honest.
I hadn't either, Dennis. Saw it mentioned several times over at Wilders.
I have a key for the paid version of Keriver Image(I pm'd the dev for it at Wilders when they were just starting up but haven't used it)
If you are already using Macrium successfully it may be overkill but as Dennis said, give it a spin and let us know what you think.
Keriver Image allows images of all partitions. 1-click only creates images of your operating system
More info here
