Login removal
Greetings!
Lately, when I run C Cleaner on my Windows 10, it removes all of my Roboform automatic login information for sites that I frequently visit, ( E Bay, Amazon, etc.).
What settings do I have to uncheck to prevent this from happening?
Thanks for any help!
Gary
Have you tried putting the RoboForm Folder or location in the exclusion list? That should cause CC Cleaner to skip it while cleaning you device!
