In Custom Clean when the program asks to shutdown Edge, it locks. Have to shut down the program and restart, then
it will work.
it will work.
In edge turn off startup boost, start with pc and allow edge and add-ons to work after close
When cleaner next asks you to shut it down, after you close the browser window, open task manager and type edge in the search box.if there is any edge still running (you may see webview app which is likely ccleaner7 and edge32update (or something like that) leave those to run
