Little problems with command line start
1. when start ccleaner from command line with parameter /AUTO, he perform cleaning files and folders perfectly, but why he don't execute registry cleaning?
https://www.piriform.com/docs/ccleaner/advanced-usage/command-line-parameters
“CCleaner runs silently and automatically, using the current set of saved options to clean the PC. CCleaner then exits.”
all my registry parameters checked and saved…
  1. if cleaning process is long (start as p.1) - many temporary files, tray icon will be showed. if click her, main form ccleaner will. And don’t close.
“CCleaner then exits.”
excuse me for my breaking english ^_^
Note: When you run CCleaner.exe using the /AUTO parameter, CCleaner does not run the Registry cleaner. You cannot currently run the Registry cleaner through a command-line parameter
too bad...do you plan make registry cleaning by command line params?
There is no "you" in this conversation, but no they don't because it is VERY HAZARDOUS to your PC to blindly "clean" the registry. And, be for you say it, just because you've not been bitten after cleaning the registry without looking, just because it hasn't happened yet doesn't mean it won't (blind cleaning blind luck). Read my signature for more on registry cleaner
pardon...
signature interesting, thank you. Link to ini is also good. Probably I'm very lucky, my registry is operational again last five years using ccleaner with maximum settings cleaning :)
