Ok when you go into tools in CCleaner and press (say startup) and go back into either cleaner or issues and then go back into tools, it still shows you in the startup part of tools. I would like this to also happen in the options tab as well....
See if you go into options its default set on settings(say if i go into about) then go back into either the cleaner, issues, or tools and then go back into options it puts you back to settings(default location)..... I would like it to also keep where you've been in the options part of CCleaner too..
Thanks Jobartley515
