Licence Key does not exits
Have just bought and paid for CCleander Pro. I have tried a lot of times to insert the licence key - but get the message Licence Key does not exist.
I have tried to contact CCleaner - but not much help to get!
Am I doing something wrong??
Michael
Take a look at the guide here, particularly the section "If you get an error saying that your license key is not valid:" which has a few tips
https://support.ccleaner.com/s/article/how-to-register-and-activate-ccleaner-professional?language=en_US
I suppose the other question has to be did you buy direct from CCleaner or from a 3rd party?
(As with everything else, there are fake sellers out there).
Hi
I bought directly from CCleaner.
The CODE is pasted and insert!
I have uninstalled and installed again and again - nothing help!
I can see that I can do anything else.
It is simply not good enough.
What do you see if you put your email address you used when you bought your software into the licence key lookup here: https://www.ccleaner.com/support/license-lookup
This is a user forum and we have no access to accounts, you will need to contact support for that.
You can raise a support ticket by using the form here: https://support.ccleaner.com/s/contact-form?language=en_US&form=general
Be aware that support are busy at the moment and it may take some days (or even longer if your email address is not recognised) before you get a response from an actual person.
It says they donot know the email address - unless this I received the Invoice at the same email address!
In that case then for some reason your email (and presumably your key) has not been tied to any active subscription.
The baest I can do is suggest that you raise a support ticket using the form I linked above.
OK thanks - I have already done this several times! So maybe it is better to cancel the order!!
i have the same problem ,,, payed for 1 year and then i get a key that dont work ...
