Large Drive
Hello,
I'm trying to recover 200GB worth of files from a 2TB drive and it says it still has 2 days to copy. What are my chances of a successful recovery? Does the time frame sound normal?
Thanks
Yes there is a chance :) my friends have deleted SOOOOO MUCH STUFF THAT I RECOVERED! If the files mean something to you I would give it its 2 days, windows dose not cover over the data it jest removes the location so you can't see it but the file is still there! And I haven't had one time it dident work for me using recuva....... Btw I dident use dbanon my data so it was easy to recover.... I Really hope this helps!
