CCleaner I use in combination with easycleaner. Further programs with similar intentions: RegSeeker, RegSupreme Pro, Registry Mechanic, Advanced SystemCare, RegistryBooster are all in use.
Too much?
I have no inconvenecies.
Too much?
Too much?
Hello cohrt,
Welcome to the forums !!!
You know it is overkill plus impossible to figure out when things go bad.
Maybe if you got rid of a lot of the dangerous Reg stuff and stick with CCleaner.
Now you can concentrate on important stuff like backing up your data etc. and having some fun.
davey
I use RegSeeker and CCleaner's registry cleaner only then a registry tuneup with NTREGOPT followed by a reboot like it recommends to keep my registry fit as a fiddle.
I do use RegSeeker's Histories ... to remove Old Start Menu and Clean StreamMRU/Stream keys items
I use Registry Mechanic, Its an advanced registry cleaner for Windows that allows you to safely scan, clean, and repair registry problems with a few simple mouse clicks. Problems with the Windows Registry are a common cause of Windows crashes and error messages. By using PC tune-up utilities such as registry cleaners regularly, your system will be more stable, your software will run quicker, and your operating system will boot faster.
Registry Easy ... .
I think I'll pass on it with the $39.95 charge because the Exorbitant number of 743 registry errors is rather inflated.
McAfee SiteAdvisor does not rate it very good:
