Hi, it used to load when my Windows 10 started. But after the last update (4.3.852.1062) it no longer does this. I've checked the setting a few times and have also turned it off and on in hopes for getting it to work again. But, no joy.
Hi @Bocool You might be able to resolve this problem using the following steps:
Open the "Run" dialog in Windows (On the keyboard, hold the "Windows" (
) and "R" keys simultaneously)
- Type: taskschd.msc > click OK
- Expand "Task Scheduler Library" > open the "Kamo" folder
- Right-click the "KamoStart" entry > click "Disable"
- Right-click the "KamoStart" entry > click "Enable"
If the problem persists afterwards, I would suggest that you uninstall Kamo, then download/reinstall the software from here:
Thanks, I'll try that. :)
