Kamo Private Connection NO Auto Start on System Startup or Reboot
Using Windows 10 Pro, After the Nov 17th, 2022, update version 4.6.891.1424, Kamo starts fine, except Private Connection that used to start Automatically does not. I have to manually turn on the Private Connection and re-checkmark all the box settings after every system boot or restart.
Everything was working fine before the program update, I also checked Task Scheduler which shows Kamo task was updated on 11/17/2022. And is no different from the previous scheduled Task setting. Is this a program change or an error in the software coding, seems like the settings are not being saved for Protection Connection being ON or OFF.
Only one topic is needed
Please stick to
Thank you
