Went to [ip8 - IP Lookup Tool] it says the VPN or KAMO does not fully protect browsing activities. It leaks. I can’t attach the print version of the report. Just quote"IP and Browser Time Do Not MatchThe time on your system (Nov 18, 2024, 23:27:09 GMT+8) does not match the time of your
IP address (Nov 18, 2024, 22:27:09 GMT+7). This can indicate that you are using a proxy or VPN service, making it easy for websites to detect.Your browser does not leak your IP address through WebRTC. Can some body help, please?
Did anyone respond to your question about this?
Many people use a VPN to ‘pretend’ that they are in another country by using an IP address from that other country.
Usually to try and get around geo-blocking, streaming restrictions, age verification regulations, etc.
The time in that other country will usually be different to the time set on your computer for your own country.
So your browser time according to your IP address will not be the same as your Windows OS time - which is what is described above.
Clever websites can query your OS time to see which country you are actually in (and thus still know that you should be blocked from accessing that website).
If you want to avoid that situation then you could change the timezone set on your computer to match the timezone of the VPN IP address, there apps available that will do that automatically for you.
Or if the VPN lets you choose then simply pick another country in the same timezone as your own country.
