im trying to install Java (jre-6u10-windows-x64) but after installed it not shows in Control Panel ..i reinstalled it again and it not shows in startup too and im trying to Scan in Secunia and it gave me message Java must be installed or i dont have java installed .
I get WAY more false positives with SUMo than Secunia or FileHippo.com Update Checker.
For example it indicates that my Creative Soundblaster software is down level and tries to get me to update my XP Home system with a 65MB Vista download.
Yes now installed and with Opera works in Secuina but FF shows this might problem loaading java and in Control Panel still no Icons.........
Sorry, I fell ill for a few days; I am back now.
By "no Icons" in Control Panel, what do you mean? Are you referring to 'Change or Remove Programs' list?
Edit: Sorry, forgot about "[...]problem loaading java[...]" in Firefox. For Firefox you are required to download an executable file which will install Flash throughout Windows rather than just as an add-on in Internet Explorer (of sort). You can download this executable here: Clicky.
