issues scan
Posted over in the CCleaner discussion forum, no responses. Don't know if this is a bug or not.
Uninstalled quick time (add/remove) but when using issues scan, CCleaner does not find any leftover registry entries for it. I can see them using regedit. Any solution for this?
Using XP SP2.
Thanks
CCleaner's 'Issues' scan is not very powerful. It doesn't find all the leftover entries, that some other cleaners find.
Solution is to use some other, more powerful registry cleaner, i.e. RegSeeker. RegSeeker is very powerful, so you have to be careful on what you decide to delete with it.
VERY careful.
