Issues not cleared under Vista
This seems to be the same problem as recently reported and responded to by suggesting using Dial-a-fix to Repair Permissions. When I tried that, Dial-a-fix informed me that it was not compatible with Vista. Are there any known procedures or software that can help with Vista installations?
That is a Vista problem, all the extra security MS have implemented.
First make sure you are running the latest version of CCleaner 1.41.544
Second try some of the suggestions in these posts:
http://forum.piriform.com/index.php?showtopic=10787
http://forum.piriform.com/index.php?showtopic=11041
Welcome and Regards
fireryone
Welcome and Regards
fireryone
Thank you for your time and trouble. Disabling UAC worked a treat.
:) chrisk
