Is Removal of Liscense Agreements and Read Mes ok?
:unsure: I just ran into problems trying to remove a spyware remover from my system, and now the CCleaner is trying to remove the all the licensing agreements and the read mes from my computer. I had never noticed that the CCleaner did that before, and am wondering if it is ok? I know that the CCleaner is working properly, and that there are missing paths to the items in question, but if it is not ok, I would like to know what I can do to keep the CCleaner from singling these out in the future?
Thank you for any help that I can get.
Hi Lilly,
Sounds like you may still have a "malware" problem.
The are Rogue Programs that claim to be spyware removers when actually they are spyware installers and worse.
I would not run CCleaner until you are instructed to do so by one of our Spyware specialists.
http://forum.piriform.com/index.php?showtopic=11000 Spyware Hell and Help
Let us know how you are doing.You need those files and should not delete them.
You are a smart user to catch that.
:) davey
