in my %PATH% and the path Ruby24-x64 <strong>does not exist. </strong>
it's not a hidden folder or anything
and <strong>yes it can be seen in explorer</strong>
Sorry, if you can see it in File explored then how does it not exist?
"Environment Path" is supposed to remove 'Orphaned' path variables, (not empty paths), so maybe some app is still refering to that path meaning that it is not 'orphaned'?
Can you not just delete it from the environment variable editor?
(Which will of course mean that whatever app is refering to it will not be able to find it, or will recreate it when next run).
i think about it and i ask me why should ccleaner find this folder if its not there and after this ccleaner report it to you?
as far as i know ccleaner find only in system-folder like "temp" for your userprofil and all kind of folders that you want to clean with "custom files and folders" and the include-option. and of course all defined app to clean what you see in the 2 searchboxes "windows" and "applications"
if this folder not more on the place ccleaner run to the next cleaning rule or not? it means if there is nothing to clean than is there nothing and no result about this cleaning-point shows you <- perhaps i go wrong with my thinking :-)
what have you set in ccleaner with your folder to clean?
