installing problem
so basically i used to hv ccleaner on my laptop but for some reason i cant run it,when i double click it, it just wont run then i uninstalled it. so when i try to install it again same thing happen and it just wont installed. anyone have the solution for this? pls help
windows version?
CC version?
AV software?
have you tried the Slim or Portable build? you'll find them here; https://www.piriform.com/ccleaner/builds
also try installing the software with the PC in Safe Mode.
