Installation problem
Hi. The problem is that I can't complete the installation of CCleaner v1.30. Installation stop working and the window error is:
ERROR OPENING FILE FOR WRITING: C:\DOCUME~1\ROBERTO\IMPOST~1\TEMP\YTB2.EXE
The program seem to work properly but no way to uninstall it.
Can you help me?
Thanks
Hello :)
I think I understand what you are saying. The installation was somehow corrupted, and now you can't uninstall it?
First download, and install VB, just in case.
I would boot into Safe Mode. The install CCleaner again (do not try to uninstall it first). Hopefully, that will reinstall it without any corruption.
If that doesn't work, it would be helpful to know what OS you are running, your firewall, and antivirus.
Good Luck,
Kristin
