Installation of CC Cleaner
I have purchased CC Cleaner a couple of years ago and now have just purchased again. Do I need to uninstall the old CC Cleaner from my computer/laptop before I activate the new one? I simply installed the current one I just bought on my laptop and now I have two CC Cleaners on the laptop.
If you have the genuine CCleaner( there are only 2 C’s) then you can just install the new version which will (should) remove the old one.
The newer CCleaner 7 has a much different User Interface than the CCleaner 6.## you would have bought a few years ago.
However if you have actually bought “CC Cleaner” (3 C’s) then be aware that is not genuine, it’s trying to impersonate the genuine article by using a similar name. At the very worst it could be malware
Thanks for the replies, no it was a digital download with two CC’s. I will contact the customer service.
