@DennisD, @Nergal: thanks for the positive feedback!
I've downloaded the newest version 1.41.537 but my suggestion is not implemented yet (which is perfectly normal because the version was released only a fortnight after my post). That said, how can I be sure that the devs have read this post?
@Super Fast:
I would do it the other way round: make it default in the Wizzard on first time use and let the user change the icons afterwards via advanced mode.
Otherwise it completely defeats the purpose!
The program must be usable for everyone, out of the box, instantly. This has nothing to do with eye candy.
The first usage of Recuva always has a sense of urgency. You accidently delete files, google for a solution, find Recuva, download and run it. At least, that's what happened to me when I deleted a folder with a few thousand photos on someone else's laptop. During such "emergencies", the last thing you want to do is waste time to figure out whether or not the icons can be changed into (more) discernible ones.
Anyway, all files were eventually recovered - thanks to Recuva.
That's good news Wim, I'm pleased you retrieved all your stuff.
The devs do supposedly read all suggestions, but sometimes it can take a while for even good ones to be implemented. However, there's no reason why you can't make a suggestion more than once.
If there appears to be nothing happening over a couple of updates, bang your suggestion in again as it's a particularly helpful one.
