Incorrect temps reported on ASUS P8P67 Pro
ASUS P8P67 Pro shows motherboard temp of 64oC but ASUS's own monitor software report 31oC. Other hardware sensors would suggets that speccy is incorrect as temps on other hardware match or are very close (within 1 degree C).
Note: This is a revision 3 board (the latest ones after the SATA bug fix)
if you need supporting files attached, let me know.
