I do not understand, why, when I use Defraggler, the computer begins to slow. by chance, Auslogics defrag creates incompatibilities with your program?
What is to defragment the files are not fragmented? I seem to notice, that the search does not find all files. I try all the files, but they seem a bit Pochini. I put it to search for files smaller and put the maximum amount.
As ever, some files, with the characters spaciali, can not be defragmented? Also in scanning and scanning space, I remain of the squares red or pink.
Could these be System Restore Points files? Check the configuration for Defraggler for some optons to EXCLUDE them.
I have not solved.
I noticed that the boot-time defragmentation(registry defrag), it does not defragment. I tried to do a scan with another defrag and it says that is defragmented 9%. I wanted to use your defrag, because it is more stable than the other.
- Boot-Time is NOT registry defrag (registry defrag is dangerous and mostly useless). All that is defragged by boot-time is the undefraggable files (page, hyber and system files IIRC)
- the 9% is both a small and unworrying amount (don't drive yourself crazy trying to get it to 0%)
- are you sure you read what you quoted? that post had nothing to do with boot-time, it's telling you to place those checks so that defraggler doesn't count the sytem files.
- some files, especially locked files (ones being used by a process) and antimalware files (ones that are protected by your security program) can't be defragged. I believe this may also be true of extremly large files (such as ripped DVD/Bluerays). what are the files that aren't being defragged?
Regarding the system restore points, Mentioned by El_Pusher
http://forum.piriform.com/index.php?showtopic=35459
those with the special character as first letter
$ Secure: $ SII, $ Secure: $ SDH, Objtd: $ O, for example.
how do I defragment mft?
Therefore, I avoid making settings-> defragmentation?
when it worked, I could not see the end sceitte defragmentation, because once started defragmenting
To defragment the MFT you will have to use another program like Ultradefrag. I hope Defraggler can include this feature in a near future.
new question, moved to it's own topic to avoid confusion
http://forum.piriform.com/index.php?showtopic=36390
