I would like to suggest that future versions of Defraggler come with the following already checkmarked:
- Stop VSS when defragmenting <Can we also add an AN here for proper English? > NTFS volume
- Use Custom Fragmentation Settings & have Hibernation & Restore checked by default
The reason for this, is I have seen a few threads where people had problems with Defraggler quitting, & this seemed to be a solution that worked for them. By checkmarking it by default, it seems that it (may) reduce problems people have when trying to run Defraggler.
If they need it unticked, it would be a simple checkmark away. See below for an example:
http://forum.pirifor...showtopic=35305
Edit: Thanks, Nerg! Yes, A goes before Consonants, & An before Vowels (A, E, I, O, U). NTFS = Consonant, so it is an a, not an.
Thanks for the correction!
