I've had/used 1.45 for years and now every couple of days it's being updated. I use BigSpeed Zipper to extract zipped files. I like it because it is very intuitive, I just move the file to the left (normally my Desktop) and then there will be a setup .exe file used to install. Now when I do it, nearly all of the files visible in this screen shot end up on the desktop. I'm not sure what happens when I choose to just move the .exe file over. It (RS) seems to function after that, however, I can't find any of it's individual files like languages. Please explain what is happening here and what I should do! Thank You!
1. Open your current installed location of RegSeeker.
2. Rename your currently installed exclude.ini file to something like: exclude_backup.ini
3. Extract the new RegSeeker into the same folder as the old one.
4. Open the exclude_backup.ini file and copy the exlusions you added to it and paste them at the end of the new exclude.ini file included with the new RegSeeker.
5. You can then delete exclude_backup.ini.
You can optionally download a customized exclude.ini file I posted here.
Thank you Andavari!
You're welcome!
I'm actually surprised RegSeeker doesn't come with an installer since it's easy enough to do with something like Inno Setup.
