I had to do a fresh install of Windows 10 and all my software including CCleaner. I'm having a few issues that I think are related to some settings on CCleaner
1. every time I login to Amazon.com it makes me fill in a code, I think this has something to do with the cookies being cleaner at exit each time. Is there a way to put a website into CCleaner so it leaves the cookies or whatever the site needs so it doesn't make me prove I am who I am each time I login?
I'm having the same sort of issue with another site that I use often, I think the answer for the above question it will fix both issues.
I think your issue is wiping session though, try unchecking that. Both are part of custom clean. Healthcheck ignores those and does it's own thing
Thanks for your reply, I checked in custom clean and don't see wiping session though anywhere. Can you please give me some more specific directions?
Under the browser (say edge chromium or firefox or what ever your browser is, is a check mark for sessions
No, checked Chrome and Firefox and sessions is unchecked
Then try cookies to keep. Visit the site and collect the cookie, then move it from the left colum to the right. In options cookies.
Thanks that worked for Amazon.com The other site I am having problems with is a 2 step issue not a CCleaner problem. Thanks again!!
<strong>You can control cookies in options</strong>
I think your issue is wiping session though, try unchecking that. Both are part of custom clean. <strong>Healthcheck ignores those and does it's own thing</strong>
Just to note that Health Check now respects the 'Cookies to Keep' as well.
It even has a way to set them up from within Health Check.
Do a Scan in Health Check and then click Privacy, then 'Manage allowed websites'
<a class="ipsAttachLink ipsAttachLink_image" data-fileext="png" data-fileid="18186" href="<fileStore.core_Attachment>/monthly_2023_12/image.png.91c6e4832aec6b66af68fdf228a4c886.png" rel=""><img alt="image.png" class="ipsImage ipsImage_thumbnailed" data-fileid="18186" data-ratio="28.60" data-unique="ifr8o5mew" width="1000" src="<fileStore.core_Attachment>/monthly_2023_12/image.thumb.png.230d9511749b1e4a15ba8d6e52b8014f.png"></a>
You then get this screen where you can add websites, or even the whole of your Bookmarks list, to the Cookie Allowlist.
Note that once cookies are added from here then Custom Clean will leave them alone as well.
The Cookie Allowlist works in both Health Check and Custom Clean.
Note - You should still use Options>Cookies if you want finer control of individual cookies.
<a class="ipsAttachLink ipsAttachLink_image" data-fileext="png" data-fileid="18187" href="<fileStore.core_Attachment>/monthly_2023_12/image.png.6c12dba127a78b515633c0a6fd7a878e.png" rel=""><img alt="image.png" class="ipsImage ipsImage_thumbnailed" data-fileid="18187" data-ratio="57.10" data-unique="10ppkluhl" width="1000" src="<fileStore.core_Attachment>/monthly_2023_12/image.thumb.png.1495680dee5323ba76b9b657b29ecf81.png"></a>
