Can't click on the Tools section? Why's that?
Well, you may or may not be able to install SP2. Anyway, if your system is running SP1 and your CD has SP1 in it, then there's no harm in using that if it's prompting you for files or something. But yeah, see if you can install SP2. If you can't, try the SSL checkmark in Dial-a-fix and hit GO.
i hav SP2 currently installed, but all i have is a SP1 cd. its asking for SP2 cd...
o and the tools thing works now, but wen i go to IErepair it says
error in iesetup.dll
missing entry: IEAccessSysInst
is there a way to download the single file somewhere?
ok i woke up this morning and IE6 was working (altho glitchy) so i tried to reinstall IE7 to get a clean uninstall it said something about missing file in the system folder and to check it.
ok i decided to restart thinking maybe it would help, it didnt. heres exactly what it says
"internet explorer could not be installed."
"please take a look at the logs in your system directory"
Can you use that xp_run_ie_setup.vbs yet?
I just applied the instructions that I gave you and it worked for me. I have done it 10 times now. But...I can use the .vbs file, and I don't know if you can use that yet.
no the .vbs file still wont work..
You said that IE6 is working now. Can you view your msn stuff now?
no it trys to bring that up in IE7. to get IE6, i hav to open IE7, then it brings up 2 windows..god its confusing.
do you have WSH(Windows Scripting Host) installed?
* Note: The problems were resolved by doing a repair installation, and then running DAF again.
