On each occasion when I close the browser a message appears saying ''Explorer has stopped working''. Within a short space of time another message appears saying ''Windows is checking for a solution to the problem'' It then finally says ''A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution available''.
My problem is how do I find out which program might be responsible for causing this problem
Question - if a solution is available where am I likely to find the answer.
In the m/time can anyone advise a possible solution. It is very annoying. Should I return to using IE 7
I'd say return to IE7 with that type of issue. If you look around these forums, and the web in general you'll discover IE8 is causing problems on some systems - while other systems aren't noticing any issues.
Hi Guys
Thanks your input. Appreciated
H/ever with a little of persistance the problem appears to have been solved as follows:
Tools / internet options / advanced / reset ie settings.
After carrying out the above not now receiving messages which appeared previously
